B7100 Top Link Length and Diameter?
Apogee
Jan 22, 2012
518
Tacoma, WA
Does anyone have an original Kubota B7100 top link that they'd be willing to measure for me? What I'm looking for is the overall length (I know it changes with adjustment - just trying to get a rough idea), the length of the body, and finally the body diameter.
Thanks in advance,
Steve
Fastest1
1994 B5200 FEL
Dec 9, 2012
52
Conroe, Texas
This is an aftermarket Cat1 top link. I am using it for a B 5200. I believe yours uses the same link. ImageUploadedByTapatalk1369669304.494609.jpg ImageUploadedByTapatalk1369669315.210285.jpg ImageUploadedByTapatalk1369669323.827382.jpg
Hope it helps.
Apogee
Jan 22, 2012
518
Tacoma, WA
Fastest1,
I appreciate the help!
Out of curiosity, do you remember where you found that?
Also, just double checking, are the ball holes 3/4"? (It's tough to tell in the pic)
Thanks,
Steve
tmessenger
B7100D P
Feb 17, 2013
40
Fairfield, IA
I have a B7100D with the OEM top link, the body is 14" and fully collapsed it is around 19" to the pin centers, the pin diameter is 3/4"
Tim
Apogee
Jan 22, 2012
518
Tacoma, WA
Well, now I'm a bit confused only because the difference is so great.
Fastest, when you have an attachment on the tractor, roughly how far out do you have the link adjusted? Is is mid-way, or is it unscrewed almost to the end of the threads?
If you had it buy again, would you buy the 9" again or would you grab one a little longer - say 11"?
I ask only because, if the OEM is 14", that seems like a huge difference...
Also, from what I've read, apparently Yanmar uses a 11" on their similarly sized stuff.
Let me know your thoughts will ya?
Thanks for the help!
Steve
Fastest1
1994 B5200 FEL
Dec 9, 2012
52
Conroe, Texas
I bought my B5200 used and had a link I thought was too long. I didn't know what was original and ordered this one because it was shorter. The prior unit would just barely allow me to level anything if it would at all. Now I am able to be more in the middle of the range of the link. 29.00 bucks off of eBay.
Fastest1
1994 B5200 FEL
Dec 9, 2012
52
Conroe, Texas
Let me say that you will have to either change one end or grind it a little as it is too wide to fit in between the mounting plates on the tractor side. Nothing you can't do with a grinder in a few minutes.
Apogee
Jan 22, 2012
518
Tacoma, WA
No problem.
I picked up my tractors as restoration projects and unfortunately they were missing the top links. Now I know what to get.
Thanks again for the help!
Steve
Apogee
Jan 22, 2012
518
Tacoma, WA
Will do. Was already planning on doing so... ;)
Just need to find project time...
MagKarl
L245DT
Aug 2, 2010
663
Olympia, WA
I'm assuming you do have the lower 3 point links?
My 3 point impliments when set up "level" have the top link pin straight up vertically from the lower link pins. Does that make sense?
So if you measure the horizontal distance from your lower link free ends back to your top link bracket, that's the dimension you are looking for.
Apogee
Jan 22, 2012
518
Tacoma, WA
Thanks MagKarl,
I'll measure it that way as well just to be sure since Fastest's tractor is a newer model than mine.
Steve
