B7100 smooth fan belt - Bando FM 34.5
AJT
Kubota B7100
Jun 22, 2024
UK
Hi
I have just snapped my Bando fan belt belt and have ordered a new one for a B7100 but it is too short and is toothed.
I have tried searching on Bando but get nothing back, so I imagine this belt is no longer made.
Does anyone have the part number for the smooth V belt (not the toothed belt I ordered!) or any compatible alternative as I can't find the correct one. 86.5cm long, 8mm wide.
Thanks
5,179
969
Try this Dayco one on Amazon.com for around $10. Size 4L380
The belt has very little stress on it. No water pump and only a low output dyno.
Amazon
2,305
Odd.
Mine has 3 pulleys- crankshaft, dynamo, and tensioner.
5,565
Looks like you have a B7100 that someone has upgraded the engine in it.
Looks like a D850 or D950 with a water pump and a real alternator.
If you give me the number that is stamped into the block just to the side of the injection pump facing up i could be able to tell you the proper belts for it.
Or just take the broken belt to a local auto parts store and match it up.
And it doesn't mater if the belt is cogged or smooth, they both will work the same.
AJT
Kubota B7100
Jun 22, 2024
UK
Thanks. I couldn’t see any number. I think my rather vague description of three pulleys was actually 2 pulleys and a tension pulley!
