Worked 6 hrs. today with my 1980 B7100 cutting & skidding firewood. Pulled with 5/16" galv. chain & slide hook attached to my 3 point "hand crafted" trailer hitch/skidding attachment. Geometry isn't perfect (trailer hitch sticks out too far - will fab up a shorter one with a loop only, no ball) but damn it worked good! Never once attempted to lift the front of the tractor even when I couldn't lift the logs & had to drag them all the way. The only log that the little Kubota refused to pull was a 16", tree-length Maple that I had to cut in half (2 X 16'). Having the ground frozen & a little snow helps also. Should finish cutting/skidding tomorrow morning & then start chunking up to take home. The Kubota is amazing, small enough to get anywhere I'm cutting without cutting/clearing roads & light enough to get across the small stream/black bog without breaking through & strong enough to handle any tree I want to cut. Beats working for a living!
