OTT'ers,
I performed some normal maintenance on my B7100 HST today, Oil Change, Fuel and Air filters. Also, I changed the radiator cap. After I finished, I started the tractor up and drove it down the driveway (200 ft) and back to the garage. When, I shut it off, I noticed antifreeze running out the overflow/whistle port at the bottom of the tractor on the floor. I did topped off the fluid in the radiator before putting the new cap on. This tractor does not have a over flow tank. Is this normal for it to discharge a puddle of antifreeze on the floor just after warming up the engine for a short period?
Also, while I am asking, how do I adjust the fan belt on a B7100? The belt seems to have some play, I would say a good inch when I press down, even though the water pump and generator seem to be turning fine. There looks like a tension pulley on the side by the oil filter. Do I have to loosen the pulley before turning the bolt that looks like a tension bolt?
AK
AK
