b7100 pto shield/rops bolts
gas man
b7100hst
May 25, 2019
cny
long story short, and a cry for help. I was removing the bolts that hold the pto guard on so I could install my new rops. all three on left side snapped. whats the best way to remove these now. I would normally heat them up and go from there but the housing isn't steel. I wish it was cast as I'd just melt the bolt out. any assistance would be greatly appreciated
cliffboyer
L3301 w/LA525 loader, G5200 mower w/RC48 deck, Kawasaki 610 Mule, DR mower
Nov 30, 2017
240
Southern IL
I would likely try welding on a nut first to see if they could be backed out.
Other option if that fails is to drill them out with a reverse-twist bit. They might extract them. Can always retap thread, even go up one size if needed.
2,240
I usually advise PB blaster, candle wax, or ATF/Acetone first, then drill for an EZ out. Just be absolutely sure you keep the drilling centered in the broken bolt. Some of my toughest repairs have been on bolts that had been drilled off center, making a difficult job even harder.
4,430
You can soak them like Bill suggested, but you probably did that already. If you can weld a nut on, the heat generated will help to loosen the crud, once it cools back down. I've welded some with a stick welder, but a wire welder is a thousand times easier! Even did some and put ice cubes on it as soon as done welding. Patience is a virtue here!
gas man
b7100hst
May 25, 2019
cny
I've been spraying with pb blaster. i'm thinking about cross drilling and then soaking through that hole. I have the stick and a mig, but i'm thinking gas welding a nut on might get a better grab on whats left ( I don't tig yet ). I do remember now welding nuts onto the studs of my old ford to replace the exhaust gaskets
torch
Jun 10, 2016
2,595
839
Muskoka, Ont.
Part of the reason welding a nut on works so well is the heat differential -- hot bolt, cold base metal -- breaks the adhesion. Then the weldment shrinks as it cools and contracts the top of the bolt slightly when it does.
Torch welding is slow and heats the surrounding base metal too much, which expands and contracts along with the bolt. Stick or MIG is preferred as the heat is concentrated and so brief it does not transfer as much heat to the base metal.
gas man
b7100hst
May 25, 2019
cny
just wanted to past an update. after a week of soaking, I welded on some nuts and no go. ended up have to run the torch on them quite hare and keep working the bolts to get them out. chased the threads and installed the rops. started mocking up the new work lights.
Lencho
B7100hst
Jan 21, 2017
409
86
NM
The new ROPS looks good. Way to persevere and thanks for posting your success. :)
200mph
Mar 3, 2017
1,228
60
PA
Glad to hear the story ended well.
