Short and sweet (long story to follow):
-Tilling my wife's grandma's garden with her B7100, I can work for about half an hour (maybe) before the oil pressure lamp starts to flicker on, increase in frequency, and it starts to feel very hot. When it does this I shut it down and let it cool down. It didn't use to get this hot or have this problem. About 4 years ago (or so) wife's cousin had it overheat (boilover) on him.
-I have made sure the radiator fins are clogged with dust/chaff (blown out and washed) and make sure it has good coolant in it (about a 60/40 mix).
-It does seem to lose a small amount of coolant, but the oil is not milky and the cooling system doesn't appear to be pressurized or bubbled when running. Coolant last changed about two years ago (and maybe 60 hours tops).
-Radiator cap rubber doesn't seem to be in great shape.
-When the coolant was changed I didn't do a flush or descaler because I read you can work stuff free and clock the thermo-syphon system.
-Oil changed every year (with not many hours) and new filter. Running 5w40 full synthetic.
So I would like to fix this for her, but I don't have a lot of my own time and money to throw at it and I don't think she has a lot of money to just throw at it, especially if its just guess work. I am sort of considering it a cooling problem, but maybe the oil pressure lamp is a completely different issue? Where should I start?
I was thinking maybe a new radiator cap, but if its not a pumped/pressurized system that probably isn't the problem is it?
I was thinking an actual coolant flush with a descaler might help? I heard to hook up a hose to force everything out backwards with some force?
Basically when I problem solve I try to do the cost benefit between the most likely causes and the easiest most inexpensive.
Thanks!!!
Long story: I use my wife's grandmother's B7100 to till her garden (about 50' x 100') and clear her driveway when it snows, that's about all it sees for work. I've been doing this for her for the last 5 years or so. My wife's grandfather was a heavy duty mechanic and purchased it new in the early 80's so I would imagine it was well taken care of until he passed away about 15 years ago. Then for the next 10 years either her tenant or one of my wife's cousins operated it for her, and I don't think it saw much maintenance in that time. Once I started using it, I dug out his manuals and did the maintenance on schedule.
When I'm tilling her garden, it doesn't take long for the oil pressure lamp to start flickering, and the air coming off starts to feel very hot. I used to be able to till the garden for a long time without any sign of it getting too hot. low range 1st gear, PTO on 2 and just go around in the hockey zamboni pattern. Soil is never very hard. About 4 years ago the wife's cousin was tilling the garden for her and it overheated. I did some reading and cleaned out the radiator fins (they had lots of dust and chaff in them) and replaced the coolant, and did the oil/filter and all that fun stuff. Seemed fine but slowly it has been getting worse and worse and now I can only seem to do a pass on 1/4 of the garden before the oil pressure lamp starts to flicker and it feels hot. Once it starts to flicker I just shut it down and let it cool down. With how bad it is now, progress is very slow and frustrating.
Edit: I know adding oil pressure and coolant temp gauges is a good idea, but I don't know if that money would be better spent at trying to fix the problem first rather than watch the problem?
Thanks!!!
