B7100 oil level
JRHill
Orange: B7100 Std and Woodmizer; Green/yellow JD Buck, Gator and 410j.
Apr 26, 2016
268
228
Wahkiacus, Washington
Have the little guy up on jack stands and pressure washing, greasing and a general checkover before winter. I checked the engine dipstick and whoa, way over full. How the heck did that happen?!?
Always a new mystery around here to solve. But counting my blessings. Seriously, this is one of the more serious problems I've had for a long time with the 'lil faded orange machine.
2,916
three things are possible :
1) YOU overfilled it ( we are gonna rule this one out!)
2) the hydraulic pump is bleeding oil into crankcase - easy to do on these oldie but goodies
3) the lift pump is placing diesel into the crankcase.
Look at dipstick under seat - IS IT LOW? if so .......... hydraulics are the problem.
Does the engine dipstick smell like diesel? Is it very thin? IF so - you found problem
I just replaced my lift pump - come to find out my POS gauge was the problem all along.
Check each and report back!
Lencho
B7100hst
Jan 21, 2017
444
115
NM
It MUST be #1. That's easy to fix though.
Hi JR, I hope you’re right and it was a filling error.
I agree with Hokie that it’s not likely if you measure the amount you add when changing. His items 2 and 3 sneak up on you.
Is yours an hst? Mine was leaking at the hydraulic pump seal and it took me awhile to figure it out.
JRHill
Apr 26, 2016
268
228
Nah, it's got gears, thankfully. I was running it around today after getting it off the stands and draining a bit of oil off. Running like a champ.
AOW162435
'25 LX2620 / '79 B7100 / '03 JD x595
Jun 16, 2023
193
111
Ellicott City, MD
On the B7100, the manual gearbox and the hydraulic system share the same oil. The hydraulic pump is engine driven and its seal can fail, leading to hydraulic oil in the crankcase. Or so I believe.
Andreas
