B7100 gear, gear oil question
BiggB
B7100D, B2030 front blade
Mar 20, 2026
64
38
New York
Good day all I just wanted to check that the recommendation for gear oil is as the shop manual says SAE 80. I’m in NY it can get cold and I don’t know if it’s ever been changed
thanks
11,022
No change, but straight 80W is hard to find and normally expensive.
Just use UDT or UDT compatible and call it good.
3,058
Go to Wallyworld .............. it happens to be on sale too.
3,058
Thanks again! I need engine oil for it too shell Rotella 15w40?
and just about finished the last of my front blade saga lol
Rotella T6.......... they have two blends... 5w-40 and 15w-40..........
the 5w-40 would be my choice in the cold of NY.
Jim L.
883
180
Just to be absolutely clear, diesel engine oil for diesel, gas engine oil for gasoline engines. They are formulated differently.
7,233
thanks
Are you talking transmission? Kubota said replace it with UDT.
5,309
I’ll second the vote for Rotella.
I’m in Mi, so we probably have “similar” winters.
My “Kubota life” started out with the Kubota brand 10w30, but found a “stupid good” deal on 20 gallons of Rotella 5w-40, so that is my flavor for now.
My truck has used a variety of Rotella flavors from 15w-40 T3 all the way to the “newest” T6 5w40.
I think they make a 0w-40 now, but I could not locate any locally when it was on “Super Special”…...
I also just go with the SUDT 2 (?) to keep things simple. Can’t hurt I figure.
