B7100 FEL hydraulics
MOW
B7100
Feb 8, 2018
Belton
I have a b7100 hst with a b1630 FEL. I recently rebuilt the motor and was wondering if there was a way to bypass the hydraulic lines going to the FEL. I would like to start the motor before I put the FEL back on. I didn’t want to run the hydraulic pump without hydraulic fluid flowing Thur the pump. I have two hydraulic lines coming out of the block and another hydraulic line going from the FEL valve to under the sit.
5,235
1,018
Just connect the two lines from the block to the loader valve together.
To the block it will seem like the loader valve is seeing flow but not being asked to produce pressure.
If your loader valve has 7 lines it means the loader valve has power beyond to supply the 3 pt hitch.
During your trial the 3 pt wont work.
4,503
Whoa - the 3pt will work exactly as it did with the loader in the circuit.
MOW
B7100
Feb 8, 2018
Belton
so connect the two lines coming from the block together and the power beyond line can stay unhooked. Just no 3pt power. Thanks that is what I needed to know
4,503
The other line is not power bryond. It is tank return. The line going back to the block is power beyond and the 3pt will work.
