B7100 clutch
DEW EVIL
Norco california usa
A friend of my wife bought her first tractor last week, and it has landed on my drive. the clutch does not disengage at all, starting to look like im going to have to open the clutch up.
My question is how hard is the line up with out the disassembly/ assembly frame?
Looks like big unit to manhandle.
Thanks for your input
Stumpy
L175
Dec 1, 2011
848
NE Ohio
Are you referring to aligning the clutch disc or the tractor halves? It's not exactly easy but as long as whatever rig you use to hold up both halves is easily adjustable it's do able. My machine is an L175 but should be about the same procedure. I used a come-along attached to a 4x4 that went across two of the attic floor joists in my barn to hold up the front end. The sling went around the casting that goes around the flywheel. There are pics of it here in my second post. The only catch is the engine can rotate on the front axle's center pivot and frequently does so but it's not awful to manhandle it back into place. Those jack stands you see were to keep it level while I worked on it, the come-along is just there for insurance in that pic.
As you've probably seen the rear I did by strapping a floor jack to the transmission. That worked beautifully. By only loosely bolting on the pressure plate assembly I was able to feed the transmission input shaft into the clutch disc and then adjust everything so it was level and then wiggle it back together. I tightened the pressure plate bolts through the access panel in the bell housing after removing them one at a time and applying red loktite.
DEW EVIL
thank you for the great pics and documentation
I do have to say I am a little intimidated by the job but think I will weld up a few jigs with bottle jacks and go for it.
