B7100 Clutch Acting Strange ???
Dan_R_42
B7100-D, w/ Sims Cab, B219 FEL, ARPS 70 Backhoe, Oversized R4 Tires, LX2610 Cab
Dec 1, 2010
447
Taunton, MA
On a B7100, what would cause the clutch to to continue to operate once it is disengaged?
After the clutch pedal is pressed the tractor continues to pull/travel for at least 5 to 6 seconds. This even happens with a full loader bucket (approx 500 #) traveling up hill. The only way to stop the tractor after the clutch is disengaged is to jam on the brakes, or it will continue moving for several seconds.
Has anyone experienced this happening?
Thanks, Dan
5,324
Mis-Adjusted clutch, bad pressure plate, Bad throw out bearing, really rusty clutch disk, pressure plate, and or flywheel.
Try adjusting the clutch pedal rod first. ;)
kubotasam
Apr 26, 2010
1,200
125
Alfred Maine
In addition to what NIW said-- A bad pilot bushing in the end of the crankshaft can cause the same symptoms.
Dan_R_42
Dec 1, 2010
447
Taunton, MA
Sounds like it may be time start gathering parts for a replacement. The tractor was built around 1980 and is still the original clutch.
Can anyone confirm the part numbers I have listed are correct for a B7100-DT
Clutch 66591-13300
Pressure Plate 66591-13400
Throwout Bearing 32150-14820
Pilot Bushing 66621-14120
Are there any other parts I should be looking to replace at the same time, once I get around to splitting the tractor this fall ?
The current plan is to try to nurse it along so I can complete my current project before tearing it apart for an extended period of time.
Dan_R_42
Dec 1, 2010
447
Taunton, MA
Any suggestions or recommendations on suppliers other than my local Kubota dealer for clutch parts at a reasonable price.
Is it is OK to ask this question here ? If it is poor taste I will delete this post...
OldeEnglish
Jul 13, 2014
768
Western, MA
You could always check your dealer's prices with online dealers to see if it's any cheaper getting them by mail. I've seen clutch parts for the 7100 on eBay, but I don't know if the quality is any good. You can't go wrong with kubota parts, they seem to last a very long time.
4,464
I recently replaced clutch, pressure plate, TO bearing, pilot bushing, and other parts on my B7100 HST.
Got all the parts from Coleman's Equipment. Not sure I would try to save money by buying aftermarket parts, since I don't like wondering if they will last. Pay a little more just for the contentment.
Dan_R_42
Dec 1, 2010
447
Taunton, MA
D2Cat, you make a good point. THANKS...
I had checked the Coleman website the other day but did not find the parts I needed. I will call them tomorrow to verify part numbers get a price. Thanks.
OldeEnglish: If the Kubota replacement clutch lasts as long as the original clutch did (35 years) I'll be happy with that !!! :D
5,324
Clutch 66591-13300
Only one has changed:
Clutch disk: 66905-13300
http://www.colemanequip.com/parts/KubotaParts/66905-13300/
http://www.colemanequip.com/Parts_Detail.asp?partID=15633
http://www.colemanequip.com/Parts_Detail.asp?partID=9396
http://www.colemanequip.com/Parts_Detail.asp?partID=15676
kubotasam
Apr 26, 2010
1,200
125
Alfred Maine
If you are ordering parts, don't forget the oil seal for the pilot bushing.
Part # 09400-14247
Dan_R_42
Dec 1, 2010
447
Taunton, MA
Part # 09400-14247
kubotasam, Thank You !!! I had no idea the bushing needed a seal. Are there any other parts I should be looking to replace at the same time it's split apart ?
Dan_R_42
Dec 1, 2010
447
Taunton, MA
I bit the bullet and ordered the parts from my local Kubota dealer.
I got:
Pressure Plate
Clutch Disk
T.O. Bearing
Pilot Bushing
Oil Seal
Now I'm wondering about a few other parts I'm finding in the "Clutch Rod Group". There are 3 Oil Seals listed with the Holder, release bearing.
66621-51420 SEAL, oil
09030-20328 SEAL, oil
09030-20357 SEAL, oil
Are these parts that usually get replaced with the clutch system ?
5,324
Give the holder a shot of grease and if it holds it your fine if not might want to replace them all.
4,464
Dan, that big seal that goes in the bell housing is FUN to get back in. If it's not in bad shape I'd leave it. It keeps grease from getting to your clutch. It's a tough neoprene material in a metal ring. Unless your shaft has been wallering around the the pilot bushing or the flex-coupling is shot you won't have any vibration to take the seal out. (I spent more time making an installation tool, and then driving the seal into place then it took to install everything from the pilot bushing to the flex coupling.)
The other 2 seals are there to hold grease in the holder. They are not expensive, but if you don't have grease slinging all over in the bell housing onto your clutch, I'd leave them alone.
Remember theses tractors were made for rice farming. Water was getting were you will never have water!!!
Dan_R_42
Dec 1, 2010
447
Taunton, MA
Thanks Wolfman & D2Cat, great advise. I really appreciate the help.
Now that I have ordered the parts, I'm hoping to be able to keep using the tractor for the rest of the summer on my project. I really don't have time to be laid up with an equipment issue. I'm hoping the clutch repairs will be my winter project.
I may be forced to see if I can find another used Kubota, if it becomes a bigger issue. :D
I need a good excuse for a second Kubota - right ??? ;)
OldeEnglish
Jul 13, 2014
768
Western, MA
I wouldn't be suprised if it did! My father's b2910 battery is 14 years old now and is finally at the end of its life, but we revived it yesterday with some water and a charge. Longest lasting battery I have ever seen in my life.
I've bought a radiator and replacement hubs off of eBay that were aftermarket. The radiator drain port was not the same size as the original drain cock. Had to drill and tap it and add a straight drain cock with a hose fitting on the outlet. That worked out for the best anyways but I had to do something with the screen mounting holes because the radiator was way off.
The hubs themselves seem heavy duty, but the lug bolts were made of cheap metal and I stripped a bunch of them hardly tightening the lug nuts.
As for a second kubota, I'm contemplating another old one to mount my MMM to and make a dedicated lawn mower. :rolleyes:
kubotasam
Apr 26, 2010
1,200
125
Alfred Maine
No matter what job someone is doing it always seems like there is one more thing that could be done. Well another thing that you could/should do is to replace the rear main oil seal on the engine. If you decide to replace this seal you need to remove the flywheel. Mark with something like a sharpie maker pen the alignment of the flywheel to the crankshaft. When reinstalling the flywheel the alignment marks make the job much easier. The bolts holes make it look like the flywheel can go on in any position and there is no dowel pin to help with the alignment. The bolt holes are actually different distances apart and there is only one correct way for the bolts to go. However the difference is so slight it is hard to see.
