Good morning. I have a b7100hst newer version and picked up a bushhog backhoe. The backhoe is setup to run off tractor hydraulics. I'd prefer to use a PTO pump and resivoir but considering the cost of all that I'm looking into using tractor hydraulics instead.
I have a b8200 pump to put on it to increase flow so that should help. I also have the b1630 loader running off the hydraulic block on side of tractor.
I've seen several references to the hydraulic port on the side of the 3ph valve under the seat but not enough to know if this idea would work. If I were to tie into that for the "In" of the backhoe and then run the "out" from the backhoe to the fill hole where my loader return line is would that work? Obviously I'm not using 3ph while I have a backhoe so that is no big deal to turn the knob to auxiliary instead of 3ph.
I'd prefer not to use the power beyond from the loader simply because of all the extra hoses I'd have going all over the place. Thanks for any insight
