B7100 AG to Turf tires
bmblank
Mar 4, 2015
626
271
Cadillac, MI
Hi all. First the question, then the back story you can skip if you're not interested.
Are the bolt circles for the front and rear tires on a '96 B1700 the same as on a '94 B7100?
Skip the following if you'd like...
I have a B7100 with some real aggressive ag tires. Fronts are 6-12 and rears are 8.3-16. I'm not sure how it ended up with 8.3-16 instead of 8-16, it was just the way I bought it. Anyway, I'd like to get some turf tires for it. On a whim, I was perusing a couple of the local dealers used tractor listings and noticed a couple B1700 with turf tires on them. After looking up the tire sizes (on tractordata.com), I noticed the B1700 takes 6-12 and 8.3-16 ag tires (no turf tire sizes were listed). MAYBE they'd be up for a trade. I gave one of them an email and found that the tires they have are front - 23X8.5-12 with a 6 bolt pattern and rear - 33X12.5-15, also with a 6 bolt pattern. They're not what the manual calls for, but they ARE right in the sweet spot for circumference ratio.
So, to recap;
I have:
6-12 AG fronts and 8.3-16 AG rears, both with '94 B7100 bolt pattern
They have:
23X8.5-12 Turf fronts and 33X12.5-15 Turf rears with a '96 B1700 bolt pattern
Would it work?
Thanks
Blank
bmblank
Mar 4, 2015
626
271
Cadillac, MI
Friendly bump...
I realize it's a little long, but the middle part can be skipped.
5,186
I don't think the fronts will have the same bolt center to center measurement, with a little die grinding they should work.
The rears are the same.
bmblank
Mar 4, 2015
626
271
Cadillac, MI
That's what I was afraid of. I'd be willing to put a little work in to make those compatible with my tractor, but I can't imagine they'd be interested in a trade if they have to put the work in making my wheels compatible with their tractor.
Maybe I'll get back in touch with them and get a measurement, just to be sure.
Thanks NIW.
