B7001 Year ?
dcmeck
B7001
May 31, 2011
Mount Perry, Ohio
Hi everyone great forum guys !
I have a B7001 4wd D750
This thing is a mule lol
I'm not sure of the year my tractor was built the number stamped on the side is B7001 53315. I have looked at the other posts to see which year matches but their our none with the same number. would it correspond to the closest number shown on the posts showing year made? IE.
1976 10001
1977 13931
1978 36646
1979 54221 ? this one
1980 64448
1981 70678
1982 74217
1983 76009
1984 77309
1985 78435
also I have several parts manuals but none say B7001
I have B4200D - 5200D - 6100D - B7100HSTD
I'm trying to find the right part number for the oil delivery pipe. Before I order it from Vic I want to be sure it's going to fit. The pipe shown in the 7100HSTD shows the pipe with the hydraulic block mines a straight pipe no block. the 4200D - 5100D and 6100D-P show the pipe like I got but different part numbers, the 4200D and 5100D are the same number but the 6100D is a different number. The pipe shown in the 7100D-P shows 2 part numbers 66704-36130 and 66711-36132 any one know which one ?
Thanks for the sight guys.
Ive learned lots already
asbug
B7001 - looks orange to me... Woods 5' scrape, 42" rotary cutter, shreader/chip.
Feb 11, 2011
155
Varnell,GA - USA
Welcome! I also have a B7001. Mine is a 'mid '77.
Most all the stuff I have had to get is for a B7100. The only thing I have seen that is different are:
Tires/wheels, PTO cover, a selector system under the seat and the throttle is backwards. (mine has a great 3pt hitch system that appears to have been on the tractor since importation (it has the same slighty faded paint on it as the rest of the unit...)
Every thing else is the same as best I can tell.
I would just get a parts manual for a B7100 and go with it.
My owner's manual for a B7100 even has photos of a B7001 in it (tires and other give aways...)
Good luck.
KC
DuckInn
B7001. 4WD. Manual shift & steering. FEL
Oct 13, 2011
15
Ontario, Canada
Welcome! I also have a B7001. ... Most all the stuff I have had to get is for a B7100. The only thing I have seen that is different are:
KC
My B7001 needed 3PH upper-arm pins. B7100 parts didn't fit. I was lucky to find a semi-retired wizard with a lathe who turned out 3 pins for me.
