g7r0a0y1edoutIN
B7001, muratori tiller, home-made leveling box, 12$ auction blade :), ......more
Recently purchased a very fine gray market B7001, in my 2 month experience of tractor, orange tractor ownership, bought it knowing 3/6 would rumble grumble n grind and reverse as well.....so I tore into the transmission in hopes of finding said problem and did, lots of shaving big and small in bottom of case as well as fine ones in the filter, also one rod holding approx. 3 gears when i move tge pto in on position rocks and rolls and hss the rear,wall all scratched up, out and cleaned now, and a thorough reading of other posts before joining indicate the sister to this machine is the B7100, downloaded a manual and a service manual for tear down, I guess I'm in more need of parts than anything tight so hope this is in the right spot, and seen that service dept vic is the dude to talk to from earlier reading, got several pics which I hope will attach without trouble.
I've searched for gaskets which seem to be non-existent in my search for gray or N.A. models 7001 and 7100,
Also I pulled the hydro pump off bc my oil was always full yet I was losing Mass amounts of hydro fluid in the case, and noticed the rubber seal was pushed out from its hole, once removed and pictured, I was able to push it back in just inside flush, will I need to tear down and replace seal?
Glad I finally joined and thanks to all members in advance and thanks for a great site
If more info us needed I'll do my best to picture and explain myself until I gain some technical terms and know how, thanks again.....
