B6200 no start
gregjo1948
B6200
Apr 28, 2022
Upstate NY 13811
Customer installed new injectors and injection pump. Engine hasn't started since. Fully charged battery and fresh fuel. I've bled the injection pump [the fuel only shot about 1/2" up/out], then installed fuel lines, and bled them. No fire--no start. Glow plugs working as they should--Air filter removed and gave the intake a shot of starting fluid and without glow plugs, no fire. Checked compression thru glow plug hole--125 lbs. Shouldn't the fuel shoot a squirt about 6-8 inches up from the injection pump? Any help will be appreciated, Gregjo1948
2,871
125 psi.......... is about 250 psi short of low end margin.
starting fluid ....... really not a good idea
2,871
