KeithBarney
B7100HST with Woods LS-72 loader. B6100-HST-D and land pride grooming mower
I am in the middle of disassembly to check / change the cam plug on my 1980 B6100E and am taking lots of pictures. I think I will have clearance to get the gear case cover off with the (undo most of the engine to front frame bolts and hinge the front of the motor up 2") trick but I have run into another thing that I am trying to figure out.
There is a lonesome 10mm bolt at the top of the gear case cover that is partially obstructed by the very bottom of the dynamo housing. The clearances look pretty tight to remove the dynamo.
How do I get access to that top gear case cover bolt?
