P.Holm
L2250 4WD,FEL,60"belly mower,60" JD bush hog,60" JD box blade-Kubota T1400
Picked this little b6000e out from behind a mower shop last month for $500 and not that the holidays are over my son and I are eager to get started on cleaning the old girl up.
Managed to scrounge around and traded some stuff for a 4 foot bush hog and a woods RM59-2 finish mower. We fabricated a setup for hanging some weight on the front to handle the bush hog(needed about 180 lb).
my dilema is this, after an attemp to heat up and beat flat the lift side of the bush hog blades they still cut crappy I was thinking a new set of flatblades and sharpening the back side would accomodate the ccw pto?
Also does anyone know the part no for a set of reverse blades for the finish mower? Does anyone have any feedback on running a 4 foot bush hog with this unit?
Also will be using to disc up our garden and the turf tires will be an issue with 2wd. will chains help or should I go right to ag tires?
We will be repainting this spring and looking forward to posting pics !
Paul
Paul
