Just picked up a project. The tractor only has 6th gear, no low, no 1/2, reverse grinds. I’m thinking trans rebuild. Any suggestions on where to get parts?
I foundI think your going to need to tear it down and find all the broken parts first as that's probably the reason it won't shift.
I would start looking for a donor B6000 or a at least a donor transmission.
Yes.Sorry for all the questions, should some of the bearings be pressed onto the shafts? So far 3 have needed to be pulled off with a bearing puller.
Thanks,
What are the chances that the reverse shaft is bent? It seems wonky when rotated but it’s a 1” shaft.
Next question is would you buy gaskets for reassembly, or use liquid gasket?
Bent shaft. Buy the gaskets.The reverse shaft does appear to be slightly bent. Could it come like this or did a 1" steel shaft bend without cracking the aluminum case?
Also, any opinions on liquid gasket?
I can find all but 1 gasket. I guess I'll make one.Bent shaft. Buy the gaskets.
Interesting, why would some of the bearings have to be pulled off then I wonder? They won’t slide back on either, they will need to be forced back on. Makes sense they should be tolerance fit since some also had retaining clips. Could this be because it’s a grey model? Or damage caused by whatever bent a shaft and probably twisted another? I wonder if I should get new bearings as well.Use gaskets and liquid together.
Yes it's possible to bend a shaft without breaking the case.
No bearings should have to be forced on or off shafts.
Kubota did not press any parts, they are all tolerance fit.
