I'm new here and first post.
I'm servicing a widow's 1973 Kubota B6000 that goes to our Church.
Changing the oil, it looks like someone was cleaning a chimney, there was so much soot.
With the drain plug and screen out I dumped 1 gallon of kero in to flush and let it drain over the weekend.
I'll have it run for 5-10 hours then change it again and use a clean pans, one for oil one for kero.
I've talked to servicing managers and they never heard of that.
It's been serviced at a Kubota Dealer every year ( I don't know how they could have missed all the issues ), it's used 30-35 hrs. a year.
Have you run into this problem, no-one has a clue. If I can get a valve cover gasket, I'll take that off and check the valve guide seals and top of head for crud.
Items I found and working on.
Woods RM59-1 mower belt had 3" play, 6 or 7 cans of belt dressing in the shed, belt adjuster not working.
engine belts loose.
radiator antifreeze low, just covering the tubes.
4 wheel drive gear oil never changed, left front had sludge.
Quick connects for loader leaking, replaced O-rings.
Rear light bulb hanging out of the rubber housing.
Steering wheel loose and someone trying to adjust gearbox without loosening the long nut.
engine belts loose.
