Need help with a brush cutter. Need either reverser or Woods Rm42KB. Any info on how I can make a "BRUSH Cutter/ Bush Hog" work on this tractor. I have a Woods finish mower but need something heavier for brush.
Thanks,
Mike
If the problem is just the reversed PTO, can you not just have the other side of the blades sharpened.
If you have a grinder and an already sourced rotary cutter, give it a try.
If IIRC the blades are just bent and sharpened pieces of 3/4" X 4" bar stock.
If you already have a lead on a rotary cutter for cheap, give it a try.
I do not think that the gear boxes on these things are monodirectional.
Just a thought, then you would not have to have a reverser or a JDM rotary cutter.
KC
