retiree-urgency abandoned
B3350, Kub. 5" rotary cutter, LP 48" forks, Titan Aerial Platform, KK XB Dump
Was moving logs from storm damage when I turned off the machine to do some chainsawing. When I tried to start, it wouldn't. Lights on panel come on and glow plug light/click comes on. My suspicion is that one of the plunger safety switches is open - either the neutral pedal switch or the pto on/off switch - these would prevent the machine from starting.
Of course, I've got the belly mower on and am parked in the field. I tried jumping the starter solenoid, but couldn't reach it. There's no way I can reach the neutral switch and things probably wouldn't go well if I tried to dissemble the seat to get to the pto on/off switch. At this point, I've resigned myself to wait for my dealer to pick it up and fix it (they're 3 weeks out to get to me). But that doesn't stop me from being "annoyed" that but for a 1 or 2 cheap switches, I could be doing the chores & projects I need to be doing.
Given my age and decreasing dexterity, I'm considering the possibility of an emergency bypass switch for these 2 switches. Looking at the schematic (it's for the cab version - mine is ROPS), when the key is turned to ACC or further it looks like the closed switches deliver 12v "signal" to the ECU. I've marked the ACC supply line with green - from what I can tell, it's an L/R wire (would that be lavender/red?). It looks like I could tap in past the safety switches (under the dash before the lines hit the ECU - marked in orange) and use a DPST switch to connect from the supply (marked in purple) to the orange taps. I need an old-geezer-friendly way to temporarily jumper these when they fail, but I'm not so far gone to forget to turn the pto off and put the machine in neutral when I turn it off.
Would welcome input/thoughts.
