B3200 no forward or reverse
Ktrim
B2400, lA352 loader,3pth quick hitch/z122r zero turn/restored 52 farmall super a
Dec 23, 2020
444
369
Nazareth Pa
When I get a chance I'll rebook at exploded view of yours. I'll have to see if it's similar inside to mine. I have a different hst in b2400
Relook. Auto correct got me
terryw
2009 Kubota B3200
Jun 13, 2023
22
Illinois
They may be similar in quite a few ways and maybe even use some of the same parts. I’ve noticed in the parts diagrams that says a particular part may have many plus uses to other models.
Ktrim
Dec 23, 2020
444
369
Nazareth Pa
Looks similar to mine. Nothing too hard about it but takes some patience putting back together. The springs in the cylinder assemblies are extremely stiff. The pistons will keep trying to pop out on you. You'll know when everything seats properly. Don't fight it together.
terryw
2009 Kubota B3200
Jun 13, 2023
22
Illinois
Okay thanks, I’ll be looking out for that.
terryw
2009 Kubota B3200
Jun 13, 2023
22
Illinois
I’ve had to take time away from this repair, life happens. Since I had over 1400 hours on tractor and 14 years old I decided to go ahead and replace the clutch. Does anyone know if the alignment tool to use is the same size as the output shaft? Mine is a 10 spline and checks .547 diameter on the pilot end of shaft and .960 across the splines. I keep seeing these tools that are advertised as .590 pilot diameter and 1.00” across the splines and also a 10 spline. Is that the one I need? I’m not sure
terryw
2009 Kubota B3200
Jun 13, 2023
22
Illinois
Ktrim
Dec 23, 2020
444
369
Nazareth Pa
A universal will work. The idea is to get the splines in the clutch disc centered in the fingers of the pressure plate. Little finesse and wiggling will get the input shaft lined up and through
moweryaviation
B3200
May 23, 2026
Nevada County CA
I am having this issue on a used B3200 I Just purchased. It pops out of gear from time to time. It makes that rattleing noise that was mentioned. Would someone tell me what that ball coupler does? I think it transfers torque from the HST pump to the inputshaft of the transmission. Is the ball coupler internal to the transmission?
10,872
Opposite, ball coupler is just a joint from the clutch shaft to the HST, it's external.
and your model has 2 of them.
