B3030 Top and Tilt Hydraulics - 3 Point Rear Remotes
jcmiller77
Kubota B3030
Nov 5, 2022
36
I have a B3030 that I just had the rear remotes added to the machine. I am looking to oder both the top and the tilt cylinders. I have taken the measurements of the current threaded rod links.
Top: 17 1/4 - 26 3/4
Side: 14 1/4 - 17 5/8
Hydraulic Options:
Category 1 Hydraulic Top Link 17 5/16" - 25 3/16
Category 1 Hydraulic Top Link 18 1/8" - 26 3/8
Hydraulic Side Link: 14 9/16" - 18 5/16
The stroke of the cylinder seem to be a little different. I found these on Agristore USA.
I was thinking to go with the 18 1/8 to 26 3/8. This way the angle is not too tight when the 3 point is fully lifted and the top link is fully retracted.
Would anyone have any experience in picking these cylinders? Any advice on these or recommendations on a different spot to buy them?
Thank you for taking a few moments to respond.
MtnViewRanch
859
298
Lakeside Ca.
Hydraulic Options:
The 18 1/8" - 26 3/8 top link would be fine, just need to grind the tractor end ball swivel down to 1 9/16" wide.
I don't think that they have a side link that will work properly. The clevises need to be the correct angles, have the proper throat depth and have the correct pin hole sizes.
Take a good look at yours before you purchase anything off the shelf.
jcmiller77
Kubota B3030
Nov 5, 2022
36
Thanks so much. I was just reading another post about that too regarding the clevis end.
MtnViewRanch
859
298
Lakeside Ca.
Look at the picture. If I remember correctly, the top clevis is at 16* with a 5/8" pin hole and the lower clevis is at 7* and has a 1/2" pinhole.
I'm not sure you will find that on the shelf anywhere. :unsure:
jcmiller77
Kubota B3030
Nov 5, 2022
36
Yeah, I was thinking that I will just buy the Kubota cylinder. Its like 600 ish bucks, so making me nuts. I have not done any welding for like 25 years and not sure I want to start again with this.
The next real question is going to be the check valve? I really like the idea of it but what would be best way to make sure I get the right one for the kubota piston?
Thanks so much for the feedback.
MtnViewRanch
859
298
Lakeside Ca.
You won't. The Kubota cylinder (if you can even purchase the side link alone) has #6 o-ring boss ports.
No one other than Fit Rite that I am aware of has #6 banjo bolts. Not that they can't be made, but you won't find them at any retail supplier that are for hydraulic pressures.
