Have a B2910HSD that overheats quite quickly. Uses coolant quickly as well but I cannot find any leaks. Have flushed the coolant system, power washed the radiator, changed all the fluids and filters. Oil is clean with no sign of a “milkshake” present. Exhaust looks normal as well with no white smoke indicating that fluid is getting burned off. Normally use this tractor to pull a 150 galllon sprayer. Any ideas?
