B2910
Bpaw
owensboro ky
I need to replace the u joints on the front assist shaft. Does anyone have any suggestions on the best way to get the shaft out? TIA
2,295
Looks like you may start with these roll pins
Butch
Kubota 2410, RC60-24B, FL1000- kubota hydrolic front snow blade- plug aerator
Sep 10, 2009
633
82
Rising Sun, MD
I agree but getting to them is almost impossible as they are between the frame and have cross members that make access next to impossible. There has to be something that I am missing on how to get the shaft out.
Guys... I replaced my u joints on the B2910's baby brother ... my B2410! I took a lot of cogitating and couple of hours to get the drive off and on my work bench to replace the u joints.
To get the the roll pins on the transmission output shaft... I carefully "Triple" measured, said a short prayer and used a small 3/4" hole saw to make a hole in the frame plate Directly over the pin.
Worked like a charm!
The reinstall took two people as I was under the tractor working the U joint back on the out put spline while my wife was observing the the alignment of the roll pin holes in the mating units. Took a couple shots at rotating the u joint to hit just the right tooth. Wifey inserted a 16# nail to hold it in place and I was off to the races. At an ACE hardware I picked up a 3/4" plastic hole cap...
This beat the hell out of splitting the tractor!
