B2650 suddenly won't start
5,420
it'd be nice, and proper , to get flat or lock washers under those nuts. that way when you tighten th enut the switch won't move 'out' on you.
BetterThanAShovel
B2650, BH77, SG0660 grapple, pallet forks, Bobcat 60" box blade
Oct 5, 2021
133
Looks like the rubber boot is a bit chewed up too ... do I see a hole in it? If so, you might want to replace the boot if you can ... help keep water and muck out of the switch itself. Like Bill, it made me smile to see you found the problem. So satisfying. I suspect that you can get the switch tightened up sufficiently with just a single box end wrench. Grasp the switch body with your left hand and use your right hand to tighten the nut on the right side of the bracket.
I zoomed in... I'm pretty sure that's just a drop of water on the bottom of the boot. It looked in good shape to me.
I think you're right, an open end box wrench might be the only thing that can tighten in there. It is a TIGHT space. I tried using some adjustable pliers to tighten it. As you can see from the picture, the handles are the same size as the opening, so no room to turn with those.
Mark_BX25D
Bx25D
Jul 19, 2020
1,785
1,301
I don't think a socket is going to fit there. But a Harbor Freight El Cheapo wrench can be ground down on the sides to be thin enough to fit in some pretty tight spaces. I have a few of those for specialty situations.
BetterThanAShovel
Oct 5, 2021
133
Heh, harbor freight. i'd forgotten about them, we only got a store in our town a year ago. That's a great idea! This is definitely going to be a special use tool, and grinding it to fit makes perfect sense. I'll try that this week.
ejb11235
BX23S, Braber BBR4G 4' Box Blade & LRM5G 5' landscape rake
Jan 20, 2022
452
327
Seattle, WA, USA
Keep in mind that the threaded part of the switch body has flats on it that you can also put a box-end wrench on
BetterThanAShovel
Oct 5, 2021
133
I can report a complete success!
I went to Harbor Freight as was suggested. I took the nut with me so I could learn its actual size. I was able to determine it is 26mm...but the only way to get a 26mm wrench at HF was to buy a 10 pack of huge wrenches for $40. I wasn't interested in that. So I looked on Amazon, and found a ratcheted box wrench for $20 that I figured would help me. And THEN....I scrolled down a little bit, and there was this little beauty:
It was only $10 bucks and was for removing the battery on some Dynabrade somethingorother...who cares...it's 26 mm, $10, and just 6" long. Perfect!
I got it and finally got out to the tractor to tighten the safety switch. I turned the key to On so I could hear the relay click on and off as I moved the treadle peddle, to make sure the safety switch was positioned correctly, and then this wrench was just the perfect length to fit in that area and tighten it good. I used a small amount of thread locker on the nut too, hopefully that slows its progress of loosening again. This little wrench now goes into the tractor-specific toolbox....
Thanks for all the help all.
ejb11235
Jan 20, 2022
452
327
Seattle, WA, USA
When I saw the Dynabrade, the first thing that crossed my mind was "bicycle tools" ... found the Park Tool SCW-26, also $10. Park Tools makes an entire set from 13mm to 28mm
