My B2650 steer wheel keeps turning slowly after you turned hard to the right or left while wheels can’t turn no more.
Thank you for your response. I’m not purposely trying to make the steering go farther. I just took notice with the suicide knob on there It’s a different positions constantly. I thought maybe there was a relief valve that is going bad or something of that sort . my father has a 2012 B 3030 and this does not occur to his tractor. What tractor do you have and does this do that to yours and there’s no way of stopping it because it’s a pain in the butt for the knob to be in different locations ? I appreciate all your help. Thanks.Are you still trying to turn the wheel after you’ve reached the travel limits? That knob moves around because the steering is hydraulically controlled. There’s no mechanical linkage between the steering valve box and the steering actuators which means the steering wheel doesn’t have a dedicated reference point.
I currently have the LX2610 and it does the same thing if I were to try to keep turning the wheel. Is the steering wheel still turning with no input from you? As for that knob I ended up pulling it off my old BX-2370.Thank you for your response. I’m not purposely trying to make the steering go farther. I just took notice with the suicide knob on there It’s a different positions constantly. I thought maybe there was a relief valve that is going bad or something of that sort . my father has a 2012 B 3030 and this does not occur to his tractor. What tractor do you have and does this do that to yours and there’s no way of stopping it because it’s a pain in the butt for the knob to be in different locations ? I appreciate all your help. Thanks.
I have a 2017 B2650HSDC-TLB and after 950 hours I had the same problem. I took it to a Shop for repair and they said the pressures all around are within spec but it's their best guess it's the steering unit. Needing it fixed I agreed, but $4500 later and 18 more hours on the machine it did it again. ($3000 of that was to R/R the cab etc) Back to the shop thinking the new part was defective. They said the pressures are all fine as before !!! Bring it back when it breaks where their last words to me.My B2650 steer wheel keeps turning slowly after you turned hard to the right or left while wheels can’t turn no more.
