I had mentioned in another thread somewhere that I was having an issue with the FEL hoses wearing badly where they make contact passing through the loops on the arm. The protection sleeve that Kubota puts on them did not help much. Two of the hoses had worn through to the steel braiding. I tried the plastic spiral hose wrap. That worked for a bit, but eventually the metal loop would catch in the gap between the spirals, deform them, and start digging into the hose. The local hydraulic shop had no other good protection ideas, so what I did was buy 4- 45 degree connectors and put them, angling down, between the hard line and the hose. This put the hoses in a much better location and angle in the metal loop. They will only slightly touch the loop with the FEL at full height.
For those of you with a B2650, and I would assume the B3350 too, slide back the protective sleeve and check your hoses for wear!
