B2650 Chippers
MINICUP28
B7610, KX-018, RTV-500, JD X758
Feb 21, 2019
101
50
COBLESKILL, NY
I have a Wallenstein BX-42 on my B7610. Certainly on the lower end of HP capability. I run it with the PTO @ 960 RPM to give it the additional inertia for larger pieces. I would not put max size of hardwood in, that is firewood. I do use the full throat capacity for deadwood or pine. No problems at all. Our main use is to clear the hedgerows around the meadow of brush,usually 1"-3"
RobC
B7610
Aug 3, 2013
Upstate, NY
We’re using the WoodMaxx on B7610. Love it. The heavier fly wheel makes a difference in my opinion. We run some decent size brush, up to 6 inches; both green and dry. Hydraulic feed is efficient. PTO shaft has clutch and we never need to replace shear pins. We can run it all day (6 -8 hrs) with no issues. My brother has the same setup, based on the positive results we’ve gotten. Highly recommend the WoodMaxx.
