B2620 not moving update and questions
BWW
B2620 ZD326 Kubota powered Bobcat
Jun 22, 2026
11
Indiana
Finally got around to messing with the little tractor. The ball coupling is defiantly stripped out! I got both roll pins out but does not appear there's enough splines to slide the coupling back to remove the shaft? So do i have to split the machine just to remove the shaft ? Where do i purchase the couplings since they are NLA? Thanks
7,103
Salvage @007kubotaguy
Those couplers were used on 100 different models spanning decades. I would think theres plenty floating around.
marrmanu
B2620 3pt chipper, box blade, post hole auger, custom 3pt chain box with hooks h
Jan 16, 2021
154
109
usa
You will need to split, sorry to say. I got some tall grass twisted around the shaft of my 2620 which tore up the shaft seals. Does the 2620 have a BH? Mine has the BH and the BH mounting brackets according to the WSM they need to come off, however I was able to split the tractor without taking them off. Had I known that the couplers were a weak spot, as mentioned, I would have replaced both them both even though they were ok.
Mike
BWW
Jun 22, 2026
11
Indiana
Mike
Thanks for the info. Still trying to find the couplers!
10,866
@Mountainman might be a source for them.
Also send these guys a message and ask if they know if they will be getting more in, they are vendor members here and they supply great parts.
whitetiger
Nov 20, 2011
3,614
2,052
Kansas City, KS
You can order parts for later-model tractors, such as the LX3310. Just don't try to mix parts from the early and latest designs of couplers.
7,103
whitetiger
Nov 20, 2011
3,614
2,052
Kansas City, KS
Thanks! I guess i can use the same shaft and balls?
They both use the same shaft & balls, but the latest version has added O-rings in the ball sockets.
The gaskets are the same, but the gasket supports are different.
I would not put used balls in the new couplers, plus I would use new gaskets and supports anyway.
There are no O-rings in the early couplers, so they would be a moot point.
The amount of work it takes to get the couplers off- why not use all new parts anyway?
BWW
Jun 22, 2026
11
Indiana
what i meant to ask was if the old part numbers of shaft ect will work with new couplers.
whitetiger
Nov 20, 2011
3,614
2,052
Kansas City, KS
First sentence of post #9: They both use the same shaft & balls, but the latest version has added O-rings in the ball sockets.
Yes, the shaft is the same on both early and later models.
