Looking for some advice. My PTO Position lever and PTO engagement lever are stuck. Tractor was running and I decided to check the PTO, cause I have not ran it in awhile. Worked fine the first try and then I tried it a second time and the lever is stuck. Now the tractor won't start. I've removed the seat to check the linkage and I've sprayed lubricant on the linkage. Thoughts??
