G Gader69 New member Equipment B2601 Jul 31, 2016 13 0 1 Lloydminster Sk. Canada Jul 28, 2017 #1 Did a quick search but did not find out the trick to changing an inner tie rod end on a B2601. How the heck do you hold the steering shaft from turning, guessing Kubota techs have a special wrench that goes on the flat spot on the LH end?
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 29,111 5,404 113 Sandpoint, ID Jul 28, 2017 #2 Just grind the right size wrench to fit the flats.
