B2601 hydraulic leak
Clownpuncher
I have a 2019 2601 with about 20 hours on it. I noticed today that there is hydraulic fluid leaking from the FEL quick connector. It appears to be coming from the front most connections. Its not a lot of fluid. A fairly steady drip. Any ideas on a fix? Thanks in advance!
4,843
1,598
Could be loose fitting, bad coupler, hose leaking and running down onto the coupler, etc. I can't say I've run into many of them leaking; but again these things are built by humans and we all agree that humans are absolutely imperfect. That's why warranties exist.
Roadworthy
L2501 HST
Aug 17, 2019
1,649
525
Benton City, WA
If you have it narrowed to a specific fitting try tightening it. If that doesn't work, it's a 2019 model with extremely low hours. The dealer can fix it, it's on warranty.
Clownpuncher
I am pretty sure it is the front most fitting. I had to go buy some bigger wrenches as I didnt have any that fir. I will try tightening them up today
