Hi all. I use my 2601 to blow large areas of snow here in NE MN. I keep the tank topped off as I've had issues w/ice in the fuel filter on a previous machine. So now my 2601 (I believe) has ice in the filter, restricting fuel flow at 3/4 - full throttle. I warmed it up in the garage to pull the filter and remove water or replace element. Now I see Mr Kubota tells me I should have the fuel tank less than 1/2 full. I'm ~1 gallon off full currently. Short of siphoning, I cannot get remotely close to 1/2 tank b4 the water in the housing refreezes. Has anyone tried removing the filter housing with the tank near full and hopefully not had fuel flowing back through the 'fuel return pipe' as noted in the manual?
I'm also open to ideas on how to prevent future water intrusion into fuel during the veritable blizzard conditions that prevail during snowblowing? I use #1 fuel, treat w/antigel, keep the tank topped off and fasten a sock over the fuel cap.
Thanks to all, gary
Thanks to all, gary
