B26 backhoe Outrigger cylinder guard.
Smokeydog
Jun 2, 2020
572
530
knoxville, Tennessee
Liked the guards on the M59. Protects against rocks and inadvertent bucket strikes. Added steps that really helped climbing up and down.
M59 outrigger
Used 5” x 17” long square tubing cutting in half long ways.
1.5” and 2” flatbar for slides.
One of four steps.
Cylinder perches that will be welded to the cylinders. The slide bars will go thru these.
Don’t need to be this heavy gauge steel necessarily but using material on hand. Work in progress.
Reactions: 8 users
Lencho
B7100hst
Jan 21, 2017
410
87
NM
Can you lift the outriggers with those on? I ask because I’m always lifting mine up to move along as I dig the trench.
They look great!
Chanceywd
Kubota L2501DT BH77 VIRNIG URG60-CT 1950 8N
Mar 26, 2021
571
408
central ny
Parts fabricated ready for fitting.
I am just thinking about you welding to the sides of the cylinders. I wonder if you will distort the cylinders a little doing it and possibly cause internal leakage? i Have attached a few things to my loader mounts using heavy exhaust clamps, if you welded your project to them and clamped them on?
Just know I tend to distort things sometimes in my welding.
Bill
Smokeydog
Jun 2, 2020
572
530
Bill
Exactly right.
The bases are 2.5”squares tube pieces. Plan on tacking then making 6, -0.5” welds. After each weld cool with water soaked rag and cycle the cylinder. Repeat 6 times per cylinder. Trying to minimize warp and heat to the cylinder seals and oil.
hoot owl
L2501 with loader and backhoe
Nov 13, 2022
51
142
Wish I had your skills. I broke a hose on my BH77 the first week I had it. Caught the hose with a root on a tree stump.
I would like to see how you have it connected to the cylinder end?
Chanceywd
Mar 26, 2021
571
408
central ny
I caught one outrigger hose on a heavy grapevine and tore that off. That was the day I started buying some spare emergency hoses and fittings. Some are longer but can get me back to the garage to order the right one for another day.
Bill
Smokeydog
Jun 2, 2020
572
530
Welded on cylinder perch/slide and heavy all thread nut to the rod.
Tack in place to check Fitment with the guard. Cooled each weld with water and blow dry with air. Had to grind a small notch in the operating deck for clearance. Made small short welds, cooling and drying after each. Peened the welds with ball peen hammer to help reduce stress from rapid cooling.
Little orange paint.
2,003
Looks great so far!
Smokeydog
Jun 2, 2020
572
530
Other side done. Guards fitted drilled and steps welded. Now in paint shop. Design. Is very forgiving as I’ve made lots of mistakes. Aligning by eye with sweat filled trifocals. Not perfect but neither is most fabrication. Just got to know how to make it work.
Smokeydog
Jun 2, 2020
572
530
Got the mega pads and cylinder guards installed. Extra steps climbing helps this grandpa.
Don’t need to dig this high usually. Hillside, creek, ponds the extra travel helps. Same with loading a truck.
2,003
Smokeydog
Jun 2, 2020
572
530
Finger greased the slides with some water resistant grease. Probably good for the next 20 years. Doesn’t have to be a tight fit and the metal I used is at least 2X as heavy as the M59 guards. Stored inside.
The steps help tremendously. Really as important as the guards. Even if the seat rotates, really can’t climb over on this tractor or small machines. Bigger backhoes I can rotate the seat and climb up and down as a normal tractor.
