B2401 Hydraulic Leak
robin416
B2401
Apr 30, 2021
17
Alabama
One of the hydraulic hoses is leaking at the bucket. Question, replace the hose and fitting?
Anything a 72 year old woman should know before tackling a replacement if that's needed?
4,497
Hoses are easy - just need to know what type ends are on it.
DrankTheOrangeKoolaid
M6800/M920, Case 780B
Sep 24, 2019
99
34
Alberta
Is it leaking from a hole in the hose or is it leaking at one of the fittings? I had a leak on my backhoe that was just an O-ring... easy fix and it only cost $0.25.
#40Fan
291
167
If you get a replacement hose, it will have the fitting on the end of the hose. If you're referring to the fitting on the cylinder, you probably don't need to change it.
robin416
B2401
Apr 30, 2021
17
Alabama
I can't tell. I'm guessing the fitting itself. I wrapped it in a light colored towel to see if I found that it might be coming from the hose but it was clean. That's why I think it's the fitting.
robin416
B2401
Apr 30, 2021
17
Alabama
It's dark now. I knew I should have taken a pic to make what I'm describing clear but I was too lazy to get my phone. I'll remedy that in the morning.
#40Fan
291
167
This is just a generic picture I pulled from the internet, but when you buy a replacement hose, it will come with the fittings I circled.
robin416
B2401
Apr 30, 2021
17
Alabama
I was hoping that would be the case. Now to figure out which one is doing it. I think there's two right next to each other.
robin416
B2401
Apr 30, 2021
17
Alabama
Let's see if I can upload these.
The other side is perfectly clean. I first noticed discoloration on the bucket but it's only become more apparent something is not quite right.
4,497
I don't see any problemwith tht hose but you can try tightening the swivel and jam nuts. They can work loose and start to leak.
#40Fan
291
167
Is that on the left side of the bucket (when looking foward from the seat)?
Could just be exhaust stains.
robin416
B2401
Apr 30, 2021
17
Alabama
It is. It would explain why I saw it on the bucket first. But as suggested by @TheOldHokie, Dan, I'll also check to make sure they're secure.
Thank you everyone. I'm beginning to feel more and more confident I can deal with this.
Sep 24, 2019
99
34
Alberta
Oil doesn't normally flow uphill... the fact that the cylinder is dirtier above the fitting than it is below suggest to me that it is not a leak. Wipe it down with a shop rag and carry on.
#40Fan
291
167
If you're seeing fluid shooting out, then yes, you have a problem. If you're just seeing the dirty soot from the exhaust, don't worry about it. Completely normal for these machines. No need to try to fix something that isn't broke and end up causing a bigger issue.
I'm sure if you look on YouTube, you can find a few videos showing the exhaust issue.
robin416
B2401
Apr 30, 2021
17
Alabama
Well don`t just leave us hanging....lol
Some other stuff has interfered with me going out and satisfying my curiosity about what's going on. Weather being the biggest part. Got some stuff rolling in now.
As soon as I can get out there and fiddle with it, I'll let you know.
robin416
B2401
Apr 30, 2021
17
Alabama
OK, a mini update. I wiped the area down and then wrapped a light blue shop towel around the fitting and hose. I'll use the tractor for a bit then check to see if the towel is clean on the inside.
