b2400HST front axle replacement
GPW
b2400HST, 2150HST
May 29, 2025
Susquehanna
Hi All, New here. Trying to deal with a a b2400HST dual speed turning front axle that broke. The pivot broke off and is stuck in the gear box. Does it just pull out or do I need to get to the pin some how? Any help is appreciated. Dj
11,279
You need to unbolt the gear case to remove the broken parts.
GPW
b2400HST, 2150HST
May 29, 2025
Susquehanna
Thank you for the reply.
if I remove the two bolts that attach the gear box to the frame, will it slide off the drive shaft or do i need to take the gear box apart?
11,279
You should be able to drop the bracket and get the unit off.
