B2400 named Betsy sometimes starts as she should, other times Betsy cranks over but refuses to start. I will try until battery is dead recharge and try and try again. Once she starts she runs the way expected and has plenty of power.
I believe it's a fuel issue as while cranking there is no smoke until she finally decides to fire. I have replaced the fuel solenoid and is acting the same. Fuel flows freely to pump. Could it possibly be a pin hold in a fuel line allowing air into system? Not seeing any leaks? After disconnected and reconnecting fuel to fuel pump she started perfectly 3 times then went back to not starting.
I should add that she did this in the past then after months of not starting well she randomly started for almost a year with very little issues Since I don't have any idea what "fixed" it the first time I can't do it again!
Would love any help as winter is coming and I need her to be reliable.
