That’s exactly why I want to trade the FEL w/ pin on bucket for another one with SSQA / bucket.Do you have SSQA on the FEL now?
If not you'll need to get the adapter.
Then you can swap between just about any SSQA attachment.
Here is one SSQA adapter.
Worksaver Universal Skid Steer Quick-Attach Adapter for Kubota LA434, LA504, & LA534 Pin-On Loader
Worksaver Universal Skid Steer Quick-Attach Adapter for Kubota LA434, LA504, & LA534 Pin-On Loader(pins not included). This interfacing adapter built by Worksaver is designed to allow the use of Skid Steer type quick attach attachments on your Kubota tractor/loader currently equipped with a...www.durattach.com
Note: Adding SSQA to that loader will greatly reduce it's lift capacity.
Thank you for your reply thoThat’s exactly why I want to trade the FEL w/ pin on bucket for another one with SSQA / bucket.
They didn't make an SSQA equipped loader for that tractor, The LA304 with a pin on bucket was the only loader that will fit it.That’s exactly why I want to trade the FEL w/ pin on bucket for another one with SSQA / bucket.
Thank you for response and info. I’m just trying to save a buck and try to use a small light grapple for brush and tree limb removal.They didn't make an SSQA equipped loader for that tractor, The LA304 with a pin on bucket was the only loader that will fit it.
You would need to sell the tractor with the loader and replace it with a newer and larger version of tractor and loader.
PS: I think I can add on the SSQA to my pins, but then need to weld on more SSQA to my bucket By then my little tractor probably won’t pickup a 100 pound log !!!!( sarcasm)Thank you for response and info. I’m just trying to save a buck and try to use a small light grapple for brush and tree limb removal.
Thanks! Can you elaborate a little in that grapple and easy Pin on attachmentWhile this is a little bit of a pain, you could get a light Grapple made to pin on.
Doing that you'll retain your lift capabilities.
There is a non SSQA adapter that will make that much easier too attach, that requires no alteration to your loader bucket.
thanks. I would like a grapple capability. I have bolt on forks and they worked ok for me to move 7 Giant water oaks after hurricane blew them down in my yard. I think a step up for me would be the add a grapple Thanks.So you want to use a small grapple? Even if you can add a pin on grapple and find one that weighs 350 lbs, you’ll be limited to about 250 -300 lbs of pay load. Maybe an “add a grapple” to the existing front bucket might be a way to go.
Or bolt on forks? That would probably preserve as much payload as possible.
Well I would tell you about it, but I can't find one!Thanks! Can you elaborate a little in that grapple and easy Pin on attachment
