thanks for your reply. I always dont give enough info.. The little tractor was running fine as usual. Then, while using it to move some tree iimbs, it just died. I was startled as to why! It did start right back up and ran another about10 mins then stopped again.. It actually acted as if I lifted up from the seat - but I didnt. Second time it stopped, I started it back up after ~30 seconds. Thats when I put it up and left it in the shop where i keep it. it did NOT spit or sputter - engine just stopped like some sort of safety switch??How did it stop? Just.. BAM, not running, like it was shut off? Or did it stumble a bit first? Does it start again? Or is it just dead now?
Diesels need 3 things to start and run:
- Air
- Fuel
- Compression
Air is usually pretty easy. A clogged air filter can rob you of power, but it would have to be pretty bad to stop things.
Compression doesn't usually go away instantly. If it does, there's usually a lot of noise with it.
That leaves us with fuel. A clogged filter (some tractors have two filters) can give you grief. If it stumbled a bit then died, my money would be on the filters.
But if it died suddenly, I'd take a good look at the fuel shut-off valve. If it fails and shuts off fuel, it's all over.
Hard to say without more info about how it failed.
Thanks Dave. Im not sure what you are saying about a 'stop solenoid' where is this stop switch located?It will help you if you do a little investigating and determine if your engine stop solenoid is powered constantly for the engine to run OR it is powered for a few seconds to stop the engine.
The next time you have it running, disconnect the electrical connector to the solenoid and see what happens.
The engine may stop immediately meaning it is powered to run.
The engine may continue to run and turning the key OFF does not stop the engine. Now you know that the solenoid is only powered for a few seconds to stop.
Once you know this operating strategy, the next time it stops, disconnect the solenoid.
Tell us if you can get it to restart easily.
On a gasoline engine you stop it by cutting electricity to the spark plugs.Thanks Dave. Im not sure what you are saying about a 'stop solenoid' where is this stop switch located?
