B219 FEL Control Valve
4,707
Many thanks again, guys! Couple more questions.... I do need to use the side ports, so do I remove the PB sleeve (?) on the side port and just use a 90° swivel adapter SAE8 to the 3/8 NPT to the IN port ...because I don't have any power beyond items? 2nd question...the hoses. My Kubota dealer said they are discontinued and I need to go to a specialty shop to get hoses made. They are 16" and 20" 1/4 NPT for the work ports 1nd 52" 3/8NPT for the In Port - is there an online place to buy these or is it a specialty shop? Thanks!
ojaikubota
I wouldcsuggest ordering evrything online.
You will need to remove the power beyond sleeve snd install a SAE'8??? plug in that port.
You can use either of the other two ports as a tank return. The SAE -8 port on the side is probably best. You will need an SAE-6 plug for the top port
Same for the pressure in port. Side port is probably best.
If replacing hoses forget OEM. You can get them in 6" increments of length - e.g. 18, 24, 30 inches. I would suggest off the shelf one wire hose with JIC swivel ends. Use SAE to JIC male adapters in all ports. Use JIC male to NPT male adapters at the tubes.
You can purchase all of that in one order from Surplus Center.
