B2150 HST
smi889
Live Oak, Fl., USA
I have the above and will not start. It was running fine doing some and I turned it off. Went to start it and I would call it loping and nothing but black smoke from the exhaust, never started. I am looking for advice to do a step by step trouble shooting. I'm sure it's getting too much fuel and the injectors open when they get enough compression. Not a diesel mechanic as you can tell. Appreciate any tips you may have. Thanks!
2,632
The black smoke indicates that it is fueling, possibly too much. Or possibly short of air.
Check that the air filter and air passages are clear of blockages. The air filter may be clogged by fine dust if that is a problem in your area, the passages may have a nest of some sort.
Are you using the glow plugs to start it cold? Or was it still warm from running when this occurred?
Not sure about what you described as loping but that might be a battery problem so if you mean it is struggling to crank the engine you can try cleaning all the ends of the cables (there are four ends to clean), have the battery load tested. It may be something in the starter circuit that is limiting the cranking speed so it struggles to get past the compression point and that is causing the loping.
If you have a decompression knob (which I doubt), use that to get it up to a good cranking speed then give it compression to start.
SDT
Apr 15, 2018
3,468
1,230
When did you last change the air filter(s)?
10,139
Did you fill the fuel tank recently?
Did you fill it with gasoline?
smi889
Live Oak, Fl., USA
I had been using it for a couple hours then shut it off. The battery seems to be okay. Didn't check the air filter but will do.
10,139
I didn't ask if it was the same fuel, I asked when was it fueled last and if there is any possibility if at any time gasoline was added to the tank.
Pull the filler cap and smell the fuel, diesel smells completely different than gasoline.
It would explain your symptoms.
Also check air filter and delivery and make sure that's not the issue.
It's rather odd that it did it out of the blue???
It's more likely that you have water or some other contaminate in the fuel and it got set into the system.
When was the last time you emptied the water out of the separator or changed the fuel filter?
You need to start with the simple things and work your way through it, as injectors don't just stick open for no reason.
lynnmor
B2601-1
May 3, 2021
1,730
1,532
Red Lion
A better statement is “DON’T USE ANY STARTING FLUID”
Understand, but I wanted him to answer a question. Broken ring lands from using starting fluid will cause low compression and a smoking situation like he has.
10,139
Nope, not black smoke, it would be white smoke from low compression.
smi889
Live Oak, Fl., USA
Did not use any starting fluid. Can see light through the filter. Will check the fuel filter for water. I'll try and start it again today and see what I get.
2,632
It started this morning with a lot of cranking?
Not sure that is really a question so I will assume you are making a statement!
If you continue to crank the engine for long periods you will eventually burn out the starter.
So I suggest that you resolve the starting issue and save your starter.
Starter cranking speed- is it as fast as you remember it always being or is it slower than normal? Have you cleaned the battery cable ends or had the battery load tested? Has the starter been tested off of the tractor?
Glow plugs- do you know if they are working? I doubt it is that cold in Florida but I use glow plugs on my old tractor ever time that I cold start it here in central Texas. I think you said it was still warm when you could not get it started but try to get it up to operating temperature or better yet work it hard for 30 minutes then park it where you want it to be, turn it off and immediately try to start it again. If it starts hard then you know it is a struggle to start not just in the cold condition.
Fuel-Answer @North Idaho Wolfman question above in post #4 and 9. You may want to change the fuel out and the fuel filters out just to eliminate any issues with that. How is the tractor running after it starts? Does it have normal power or not? When it starts is it belching a lot of black smoke that clears up after a few seconds or minutes? What color is the smoke when it is running? Has it been run out of fuel recently?
Air-how was the air filter?
Compression- have you done anything to the engine that could have caused the compression to change? Adjusted the valve train, run it hot?
Do you understand what the diesel engine requires to start and run or are you more familiar with only gasoline engines?
You need to provide fairly clear answers and descriptions of the problems to get good answers.
smi889
Live Oak, Fl., USA
The air filter is clean. I think one of the cylinders is bad and it does make a clanking noise while turning over. I think I understand the basics of diesel, where the compression opens the injectors and heat takes over for firing. Like I said earlier when it happened initially it cranked but was putting out black smoke and not starting. Haven't done anything to the engine since I bought it used many years ago.
SDT
Apr 15, 2018
3,468
1,230
"[C]lanking noise?"
This is not a good sign.
Have you used starting fluid in the past?
SDT
Apr 15, 2018
3,468
1,230
Bingo.
Cranking motors are intermittent duty, intended only for short periods of operation followed by lengthy cool down periods.
Excessive cranking will, indeed, burn out a cranking motor.
SDT
Apr 15, 2018
3,468
1,230
Some models have both inner and outer air filters. Not sure about your 2150.
Verify if there is a clean inner filter if equipped.
