B2150 HST
smi889
41
Live Oak, Fl., USA
I have the above and will not start. It was running fine doing some and I turned it off. Went to start it and I would call it loping and nothing but black smoke from the exhaust, never started. I am looking for advice to do a step by step trouble shooting. I'm sure it's getting too much fuel and the injectors open when they get enough compression. Not a diesel mechanic as you can tell. Appreciate any tips you may have. Thanks!
2,612
The black smoke indicates that it is fueling, possibly too much. Or possibly short of air.
Check that the air filter and air passages are clear of blockages. The air filter may be clogged by fine dust if that is a problem in your area, the passages may have a nest of some sort.
Are you using the glow plugs to start it cold? Or was it still warm from running when this occurred?
Not sure about what you described as loping but that might be a battery problem so if you mean it is struggling to crank the engine you can try cleaning all the ends of the cables (there are four ends to clean), have the battery load tested. It may be something in the starter circuit that is limiting the cranking speed so it struggles to get past the compression point and that is causing the loping.
If you have a decompression knob (which I doubt), use that to get it up to a good cranking speed then give it compression to start.
SDT
Apr 15, 2018
3,454
1,223
When did you last change the air filter(s)?
10,054
Did you fill the fuel tank recently?
Did you fill it with gasoline?
smi889
41
Live Oak, Fl., USA
I had been using it for a couple hours then shut it off. The battery seems to be okay. Didn't check the air filter but will do.
10,054
I didn't ask if it was the same fuel, I asked when was it fueled last and if there is any possibility if at any time gasoline was added to the tank.
Pull the filler cap and smell the fuel, diesel smells completely different than gasoline.
It would explain your symptoms.
Also check air filter and delivery and make sure that's not the issue.
It's rather odd that it did it out of the blue???
It's more likely that you have water or some other contaminate in the fuel and it got set into the system.
When was the last time you emptied the water out of the separator or changed the fuel filter?
You need to start with the simple things and work your way through it, as injectors don't just stick open for no reason.
10,054
Understand, but I wanted him to answer a question. Broken ring lands from using starting fluid will cause low compression and a smoking situation like he has.
Nope, not black smoke, it would be white smoke from low compression.
smi889
41
Live Oak, Fl., USA
Did not use any starting fluid. Can see light through the filter. Will check the fuel filter for water. I'll try and start it again today and see what I get.
