next2dixie
B2100HSD w/mower, Woods L84 fel,tiller,blade,plow;'46 IH "A", '51 IH Cub
My Kubota has an intermittent three point hydraulic problem. Things were working normal while pushing snow for a couple of hours using a 3 pt blade, then no lift... The power steering and hydraulic trans worked fine, but the blade would not go up. I shut the tractor down and checked the hydraulic fluid level, looked for fluid leaks and proper linkage hook up to the position control valve. Every thing looked fine. Started it back up, ran it up to max RPM, nothing ... Drove it back to the pole barn dragging the blade behind me. I shut it down and looked it over again, didn't see anything out of line. Started it and up went the blade, at idle of all things. This AM when I started it the lift worked, but when I got it up to the shop it quit working, shut it down restarted it and the lift worked. I've had the tractor about 2 months, it's a B2100HSE with 420 hrs showing. Who owned it before me only used it with a belly mower. The lift will hold in the up position with a load when the tractor is off. Again, the hyd. steering and trans work fine. The hyd fluid, filter and suction screen all have been changed/cleaned before I bought the tractor. I'm thinking the problem could be trash in the system holding open a relief or control valve some where. If anyone has had this problem or knows what the fix is I'll be ever thankful to hear from you. Thanks y'all, Next2dixie in VA.
