B21, is it actually a B2110 or something else?
100 td
Aug 29, 2015
1,776
ɹǝpunuʍop
Hi folks,
I'm chasing info on a B21 (TLB), I'm wanting to know if a B21 is really a B2110 plus the bucket and hoe? Reason, I can't find a WSM on a B21, but there are others around including a 1710/2110/2410/2710 combined manual and am wondering if it's exactly the machine hiding under the B21 label? I don't want to pull the machine to pieces yet, but may have to to repair the brakes. I'm currently changing oils and filters and getting some general maintenance out of the way and a service manual would be handy. Can I work of the specs in the 2110 manual?
Thanks
Warren
coachgeo
Nov 16, 2012
2,460
32
Southern OH
Hi folks,
I'm chasing info on a B21 (TLB), I'm wanting to know if a B21 is really a B2110 ....
Warren
Where on the tractor is there something that indicates it only as a B21? Is there any writing on it in Japanese? I did look and there is no Grey Market B21 listed.
Pictures will help a ton.
100 td
Aug 29, 2015
1,776
ɹǝpunuʍop
http://www.tractordata.com/backhoe-loader/000/1/4/147-kubota-b21.html
https://www.youtube.com/watch?v=nbxYSECBcJk
I'm hoping I can find a manual on the HST and hydraulics from another tractor which are the same as a B21. Generally they would use an engine and/or HST in a few different tractors, I need to find something that uses the same running gear and see if I can find a manual on the net for it somewhere. I don't need bucket or hoe hydraulics particularly, but the main gear would be good.
coachgeo
Nov 16, 2012
2,460
32
Southern OH
My bad, should have looked at your country before replying.
Funny thing is at Tractordata.com the B21 is NOT LISTED but can be found via a search. The B2110 you speak of is not listed at all nor can be found by searching that site.
Hopefully someone more familiar with Australian models will pipe in. In the mean time here is a free manual. Maybe you can compare info there with your tractor to get an idea how similar they are
https://www.coppard.co.uk/pdf_admin/Kubota B2410 service manual.pdf
5,305
B21 WSM
P/N 9Y011-12011
The B21 is not like any other model, yes it will share some of the same parts but it's not the same.
100 td
Aug 29, 2015
1,776
ɹǝpunuʍop
Thanks,
Messicks USA (and probably others wont sell to OZ), a couple on ebay at $175(used) and $210(new) delivered, I'm hanging out for a cheap one. I won't count my chickens till they hatch, but I've had a promising offer of one, will let you know how it goes!
The 1710/2110/2410/2710 link is what I have already (thanks anyway) but I need to know if it's correct before I pull things down on mine!
Hopefully this other offer will pan out.
