B21 BT751 Backhoe hose replacement source
Ricknsharon
Kubota B21 with BT751 backhoe
Jan 8, 2022
Charlotte, NC
My B21TLB with BT751 backhoe has blown the main connecting hoses between the backhoe and the tractor over the last couple of years. Last week a hose in the bundle leading into the boom started weeping, so I decided to replace all of the hoses in the boom.
I marked all of the hose ends with colored tape and took pictures for reassembly. After removing them all I cleaned them the best I could and placed them in a plastic garbage bin and took them to a hydraulic hose shop nearby. They took the bin with old hoses in the back room saying they'll get right on it. Two hours later they hand me the eight new hoses and a $1,200 bill. That was double the price of what I was expecting but paid them and left, taking my old hoses with me.
When I got home I noticed the new Aeroquip hoses diameter was slightly larger than the old ones, ~.800" vs. .640" of the old ones. With the spiral wrap outer protection (old ones had that also) the six hoses are now too large to fit through the opening right above the pivot where the boom cylinder attaches to the frame.
Has anyone else run into this problem? Does your hoses have spiral wrap protection in that area?
I feel they should have asked me if the larger diameter was going to be a problem and I would have answered yes, because I know that area was a tight fit getting the old hoses out of. Did I just throw $1,200 away and need to buy OEM hoses?
Some helpful tips for others considering this:
To do this hose replacement AFTER you blow a hose will be much harder since you need to extend the dipper arm, swing the backhoe to one side, then lower everything to the ground to remove the boom cylinder to the boom cylinder hose connections. That will not be an easy task once you lose hydraulics.
I placed old cardboard boxes, flattened out, on the shop floor before starting this. You will have oil everywhere. Have lots of paper towel available to soak up the excess as you remove each hose. The end of the boom cylinder will be very greasy since it has nowhere to go when you grease it. Lots of grease in there after many years. More paper towels needed.
When reinstalling the boom cylinder place a small rope (Clothes line) under the cylinder and leave 20" or so on each side before installing the cylinder back into the boom. You can reach in through the dipper hose slots on top the boom to grab the rope ends and use the rope to lift the cylinder into place to reinstall the pin.
Another important note. Since the tractor end of these hoses have an angled fitting, you need to clock the hose correctly as you tighten the hose on the boom cylinder. Otherwise when you try to attach the hose to the hose to the valves it doesn't line up and you'll have to remove the boom cylinder again. Ask me how I know!
Clock all hoses in a neutral position as when the boom is centered. That way they only twist a little each way as you swing the boom.
7,386
If the new hoses wont fit you wasted $1200.
Thats quite a bit of difference in diameter and suggests they gave you 1/2" instead of 3/8" hose. The OD of most 3/8" two wire R16 hose is roughly .67 while 1/2" is .81. If thats the case I would have a "friendly" discussion with the hose shop.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
4,059
2,503
WestTn/NoMs
I don't know if you're asking for input or not, but in case someone in the future finds this thread, here's my experience. Bear in mind that I have a BT900 which is similar to your BT751, but it's not one.
• When you reinstall that cylinder in the boom, the fittings have to be up or down, I don't remember which, the same way they were. Otherwise they'll interfere with the inside of the boom somewhere in it's range of motion.
• I had my first replacement hose made at NAPA. The swivel nut was one wrench size larger than original and I had to grind the slot wider where the hose goes through the boom.
• Sounds like your shop used a heavier duty double-braid hose than what you took off.
• If you have time, you can order almost exact duplicates on-line from Discount Hydraulic Hose or other dealers. But you have to measure them and specify the ends. They have guides that show you how.
• Kubota mostly uses JIC swivel nuts on their hoses. But just because they use a #6 (3/8") hose doesn't mean you can assume it's a #6 swivel. In fact, K is fond of using #8 swivels on 3/8" hose. Since JIC uses imperial threads, I find a 9/16" NF and a 3/4" NF bolt come in handy as thread gages.
• I like the 100R16 hose. It has two braids, but is more flexible. The dimensions and pressure rating are on their site.
• Many of the hose ends have angle fittings. These come in different offsets and you have to be careful to order the correct one.
• My hoses all ran through one large braided sleeve in that shoulder joint.
• It would be nice if someone would give the size, length and fittings vs part number for others to reference without having to wait until the old one is off.
3,168
I would take the hoses back and tell them that the are larger in diameter than what you brought in for them to match, and they are too large to fit in the area of the boom where they are needed. They will probably just make you the correct size hoses and take back the incorrect diameter hoses. I think you may get some money back also if the hose is cheaper per foot, but I would ask about that before they know they messed up on your hoses because they will probably tell you that they are the same cost.
Good luck.
