B20TLB lacking loader lift power
Gromano
B20, TL420 Loader and BT751 Backhoe
Sep 12, 2025
9
Arnprior, ON
Hello,
I have a 1990 B20 TLB that is lacking loader lifting power. I know she is old, but she has been well-maintained, and it is now probably in need of some new hoses and seals. However, I have been reading that it may be possible to slightly increase the hydraulic pressure by installing shims to the main relief valve. I am hoping someone out there has experience doing this on a B20 that could give me some advice. Thank you.
2,801
I would encourage you to get some fittings and a 3000 PSI gauge and test the pressure before you try to change it. You will need it anyway to shim the pressure relief valve.
You can put the gauge onto a FEL (cylinder) hose connection and operate that valve to test the pressure. So the fittings should adapt the gauge to the disconnect on the tractor side of the hose connection.
6,764
Hello,
A very frequent cause of loader problems is bad backhoe connections. That would be my very first suspect.
Gromano
Sep 12, 2025
9
Arnprior, ON
I hope to spend a bit of time this weekend looking into it. I am going to put it through its paces and check exactly what is working and what is questionable. Thank you.
