B2030 front blade frame install
BiggB
B7100D, B2030 front blade
Mar 20, 2026
58
36
New York
Does anyone know the width of a b7100HST transmission? The reason I ask is I got my front blade media blasted and painted had some welding repairs done now trying to install it for real and I seem to have about an 1 1/4” discrepancy in my center mount. The blade did not come with the tractor I got it separately so I’m wondering if it was an hst tractor I believe they are wider than a gear transmission. IMG_1197.jpeg IMG_1196.jpeg IMG_1195.jpeg IMG_1196.jpeg
BiggB
Mar 20, 2026
58
36
New York
After putting it where I believe it’s supposed to go on the left side and using some drifts to get it about in the right spot I’m about 1 3/16 off which I’m going to guess is the difference in the width of an hst & gear transmission.
So I’d like your input I see 2 ways to go here make up a spacer block to go between the center bracket and the transmission case or shorten the bracket and put the spacer between the frame and the center bracket ( it sits properly between the legs of the front frame)
BiggB
Mar 20, 2026
58
36
New York
Does anyone know the width of a b7100HST transmission? The reason I ask is I got my front blade media blasted and painted had some welding repairs done now trying to install it for real and I seem to have about an 1 1/4” discrepancy in my center mount. The blade did not come with the tractor I got it separately so I’m wondering if it was an hst tractor I believe they are wider than a gear transmission. View attachment 176325 View attachment 176326 View attachment 176327 View attachment 176326
Messicks for the absolute win on this one! I looked up the part number for the belly brace and called Messicks it’s still available but the B7100 they said wasn’t listed as a model for this part I ordered anyway on Monday it just showed up 20 min ago low and behold it’s the correct part & took all of 5 min to install it I never get this lucky I may need to buy a lotto ticket 😂🤣
dean22
New Jersey
Finding the correct parts can be such a headache when models aren't listed correctly, so it's great that you managed to get it sorted out so quickly.
BiggB
Mar 20, 2026
58
36
New York
Well it’s almost done I believe I’m down to the hydraulics I’ll start a new thread for that. Now the faded paint on the tractor looks even worse 🤣 and Messicks having that belly brace really helped it literally bolted in perfectly.
