B1750 HSTD transmission problem.
jhbau1000
US
My B1750 all of a sudden started driving backwards. If I push the pedal forward it goes in reverse. If I push pedal in reverse it goes forward. All linkages look fine nothing lose.
Sent from my SAMSUNG-SM-G920A using Tapatalk
beaterboss
L3901, LA525-FEL, BMLX-3164 3pt Blower, 72" Coteck Sno Pusher, 60" Box Blade
Feb 20, 2017
152
St.Francois,New Brunswick. Canada
Are you sure ur tractor isn't female? LOL!!
MadMax31
BX23S, 60" MMM
Nov 5, 2014
766
New York
This may sound stupid, but the only thing I can think is ( because you didnt mention anything about hoses or any maintenance done ) your engine spinning reverse, hydraulic pump spinning wrong.
Ive seen an Osh Kosh run backwards and it was hysterical. Id imagine the hydraulic pump can only pump one way, let alone soft suction hoses and non pressure rated fittings that would blow it that were the case?
6,621
This is what I thought of too. :rolleyes: :eek: ;)
whitetiger
Nov 20, 2011
2,946
1,401
Kansas City, KS
Sounds like one of the valve plates in your hydro has broken or turned out of position.
6,621
Oh we are the bearer of joyful news! :eek:
That does make more sense than the engine running backwards! :(
jhbau1000
US
I'd say something broke as it was doing fine I loaded it on trailer to go and mow my son's yard and I got on to unload it when push pedal to back off it took off forward.
whitetiger
Nov 20, 2011
2,946
1,401
Kansas City, KS
I have a B6100 at the shop doing the same thing, still waiting for the customer to OK the tear down to confirm failure.
jhbau1000
US
Whitetiger, did you get to tear down B6100. Would love to know what you found out.
